Reply
firmware update checksums
bernuli01
Follower
2 questions.
I have a WNR3500Lv2 running V1.2.0.54_50.0.94 which i purchased new recently.
I downloaded firmware V1.2.0.56_50.0.96 directly from the NETGEAR product support page. But how can I verify the download? Are there any checksums posted so I can insure the firmware came through as expected?
Also, when I do a firmware update check using NETGEAR genie it returns "No new firmware version available". However, netgear website lists 1.2.0.56 as the current version. Why is that?
Thanks.
Message 1 of 3
TaterSalid
Virtuoso
Re: firmware update checksums
If you pull the update directly from Netgear it should be fine. I have not seen this question before so I don't think there is a problem.
The Firmware Check is frequently behind. Just trust what the update page at Netgear says.
Message 2 of 3
antinode
Guru
> [...] how can I verify the download? Are there any checksums posted so
   Netgear doesn't publish checksums for its firmware kits.  The zip
archive structure itself includes CRC-32 checksums, and any competent
unzip program will complain about a corrupt archive which is identifed
by a bad internal checksum.  (If you can, try to damage a zip archive,
and see what happens when you extract its contents.)
   So, you can't verify authenticity, but you can verify integrity with
some confidence.
> [...] Why is that?
   Netgear's firmware distribution procedures seem unlikely to win any
awards for organization.  Search these forums (or the Web) for more
instances of similar questions.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 712 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
