× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
firmware
wags3
Follower
firmware
I have a WNR100v3 router and it says a firmware update is available. When I click check for updates it does not seem to connect to the Netgear site. Any help would be appreciated. Thank You in advance.
Message 1 of 2
Accepted Solutions
Guru
Re: firmware
I take it you mean the wnr1000v3?
You can manually download the update and install it? I highly recommend doing it this way as it tends to have the best results anyway
https://www.netgear.com/support/product/WNR1000v3.aspx
Might be time to check into an upgrade. that router was released in 2010. getting a bit on in the years and it was a pretty base level router when it was released anyway.
Message 2 of 2
All Replies
Guru
Re: firmware
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1119 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
