Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
05:35 AM
2011-08-19
05:35 AM
good neighbor policy
as we all know N wifi is supposed to use then when using channel bonding if it detects congestion around you isnt it?
i wonder how many router actually do this through
just look at around me
Message 1 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
05:59 AM
2011-08-19
05:59 AM
Re: good neighbor policy
You have great signal output compare to other. Seems others are pretty far away from you so should work pretty well.
I take it's lowering to 150Mbps?
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 2 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
11:58 AM
2011-08-19
11:58 AM
ccampy wrote: i wonder how many router actually do this through
I assume you are NETGEAR1?
How the heck did you and TALKTALK-488512 manage to do that???
Are you using the original Netgear firmware, or are you using open source?
jmizoguchi wrote: You have great signal output compare to other. Seems others are pretty far away from you so should work pretty well.
Do you really think that this should make a difference June?
jmizoguchi wrote: I take it's lowering to 150Mbps?
It's showing 270Mbps for both bonded networks. I am guessing you are asking if the mode will automatically adjust to 150Mbps when in actual use? I'd be interested in knowing too.
Message 3 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
02:08 PM
2011-08-19
02:08 PM
will not use 270Mbps.. should be down 150Mbps
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
02:30 PM
2011-08-19
02:30 PM
Nope conection speed is 270mbps using a wna3100 adapter
Message 5 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
02:35 PM
2011-08-19
02:35 PM
then are not using "good neighbor policy"
it lowers the Mbps if channel become an issues. You have good signal over rest of numerous listing of SSID's
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 28
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
02:40 PM
2011-08-19
02:40 PM
I see that Netgear1 is 35 db above the closest other user therefore it should stay bonded. I have bonded with 25 db of seperation with a 3700 & 4000. Just because other ssid's are visable it does not mean they are interferring. Below is a question I ask Netgear Engineering last week.
[FONT=Calibri]1)
[/FONT]What is the dbmv threshold it uses to determine if it detects an HT20 and then reverts to HT20 automatically itself.
Netgear: Actually, this is technology from chip vendor and they didn’t share it with Netgear, so I have no value about this.
My own testing showed that if it's 25 db lower than yours it will work. Tested in my home.
I hope this helps to answer your question.
Message 7 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
02:42 PM
2011-08-19
02:42 PM
Im Using a dgn2000 and the about 6 of the routers are within a 50m range there probally low strenth due to the fact that around 14 of them are using 3 or 4 channels
Message 8 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:03 PM
2011-08-19
03:03 PM
do you actually see performance issues? it seems you are in good shape.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 9 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:15 PM
2011-08-19
03:15 PM
Performance is fine get the full throughput of my conection around 4.2-4.7 mb on a 5mb line ping is reasonable at around 2ms to router at about 7m away all good
Message 10 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:19 PM
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:26 PM
2011-08-19
03:26 PM
When I read his first post to me it seemed he was questioning if the GNP was being used based on his screenshot. I could be wrong though. I think he was surprised to see that his was working.
Message 12 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:26 PM
2011-08-19
03:26 PM
sounds like good to me and you are at 7M (22ft) from the router and you are happy with it then should be all good.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 13 of 28
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:27 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:35 PM
2011-08-19
03:35 PM
searay wrote: My own testing showed that if it's 25 db lower than yours it will work. Tested in my home. I hope this helps to answer your question.
Thanks for all that info, especially seeing that it's based on actual tests that you have carried out.
ccampy wrote: Performance is fine get the full throughput of my conection around 4.2-4.7 mb on a 5mb line ping is reasonable at around 2ms to router at about 7m away all good
Good. Maybe I'll give it a try sometime.
Message 15 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:39 PM
2011-08-19
03:39 PM
Ahh! Maybe you noticed (like me) that someone is using channel 13.
Message 16 of 28
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:45 PM
2011-08-19
03:45 PM
Joe,
Your welcome, After the other thread with marauder with his 4000 not staying bonded I spent hours testing it. Not sure if you read it but after all that it was his WIFI card/ firmware. Take care , it's miller time.
Message 17 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
03:55 PM
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
04:01 PM
2011-08-19
04:01 PM
Uk based on the ssid's is my guess, I saw 13 being used too.:eek:
Joe_ wrote: Ahh! Maybe you noticed (like me) that someone is using channel 13.
Message 19 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
04:14 PM
2011-08-19
04:14 PM
InSSIDer only shows the router beacons, and not activity, it does not show any associated wireless clients. This is just a guess, but maybe the Good Neighbour policy code only activates if it detects data transfers on other networks?
Message 20 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-19
04:19 PM
2011-08-19
04:19 PM
In regards to the channell 13 router the huawei hg520b has a bug were it can allow channell 13 to be uses on the uk settings
Message 21 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-20
08:43 AM
2011-08-20
08:43 AM
searay wrote: Joe,
Yes! I followed the complete thread. That is why I said "based on actual tests" although I didn't know how much that testing was. And yes, I enjoyed a lager or two last night too!
ccampy wrote: In regards to the channell 13 router the huawei hg520b has a bug were it can allow channell 13 to be uses on the uk settings
I wonder if he/she knows that, regardless of the bug, it's illegal?
Message 22 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-20
09:53 AM
2011-08-20
09:53 AM
Joe_ wrote: Yes! I followed the complete thread. That is why I said "based on actual tests" although I didn't know how much that testing was. And yes, I enjoyed a lager or two last night too!
Several router ive seen have allowed 13 on uk setting even through it cant be used
Message 23 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-20
10:15 AM
2011-08-20
10:15 AM
Uk & US should use channel up to 11 while Asia market uses uptp channel 13
Pretty sure UK should be upto channel 11 if you choose UK as region
Channel choices are consider by the FCC and should follow within...
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 24 of 28
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2011-08-20
01:51 PM
2011-08-20
01:51 PM
The UK allows channels 1-13.
http://en.wikipedia.org/wiki/IEEE_802.11#Channels_and_international_compatibility
Message 25 of 28
