Reply
i forgot my security question
Ab1989
Follower
good afternoon..,
i forgot my security question ..how can i updated
 Default Gateway . . . . . . . . . : 192.168.0.1
admin and password is not working
please i need help...,
Message 1 of 3
William10a
Master
Re: i forgot my security question
The device model would help. One way would be to do a reset and set up but may be a better answer if reply with the model number of your device.
Message 2 of 3
Reset to factory defaults using the Reset "pinhole" on the back.
You'll lose your settings, but that is what you have to put up with if you forget important passwords.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Discussion stats
  • 2 replies
  • 50948 views
  • 6 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
