Reply
n600 router not displaying GHz lights
neiko5
Follower
Router not displaying any lights for either of the 2 band Ghz? Is it broke and needs to be replaced??
Model: WNDR3700v2|N600 Wireless Dual Band Gigabit Router
Message 1 of 2
antinode
Guru
Re: n600 router not displaying GHz lights
> n600 router [...]
   "N600" is a speed, not a model number.  Look at the product label.
   Is that accurate?
> Router not displaying any lights for either of the 2 band Ghz? [...]
   Other lights are lit?  Here's a radical concept:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual ("WNDR3700v2 Setup
Manual"?).  Read.  Look for the LED descriptions and "Troubleshoot".
Pay particular attention to the "WLAN On/Off" button.  Did you press it?
(Further reading might be helpful, too.)
> [...] Is it broke and needs to be replaced??
   You tell us?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 306 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
