× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
phishing email or authentic? How to know
1JohnDavid1
Initiate
I received a NETGEAR notice of a firmware update, but th elinks went to "click.e.netgear.com" which did not seem right to me.  The email looked auithtic and I was able to obtain the current update via NETGEAR Genie (avoiding all links in the email.  Still, I'm wondering if this was an authentic email.  Scammers are getting crafty.  Thanks in advance for you help.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 5
Accepted Solutions
Re: phishing email or authentic? How to know
@schumaku wrote:
Discussed and explained several times in the community.
Indeed:
fake email from netgear. - NETGEAR Communities
Strange mail from Netgear? - NETGEAR Communities
firmware updates Legitiment? - NETGEAR Communities
And that's just the latest episode.
Message 3 of 5
All Replies
schumaku
Guru
What should be wrong with that?
Definitivley authentic - assuming you received the same as everyobody else.
Netgear isn't really crafty - it's a lame message, reminding to many receivers as Scam.
Message 2 of 5
Indeed:
Message 3 of 5
1JohnDavid1
Initiate
The web address was not netgear.com nor community.netgear.com.  That's what flagged a potential problem.  By your questioning my concern, I'll assume netgear also uses e.netgear, although I don't understand it.  Thanks for your response.
Message 4 of 5
schumaku
Guru
click.e.netgear.com it is - every marketing organisation does somehow collect counters of clicks to check the effectiveness of a campaign. To create a little bit more confusion, this is just a cname for click.virt.exacttarget.com - and that domain and the service is owned by salesforce.com.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3217 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
