Reply
Highlighted
Follower
power light blinking; no internet
My router seems to lose the its firmware every couple of months... how do I fix it again? the power button is slowly blinking green, the internet is wired from the modem, directly connecting my computer works, but when I connect the router, I get the blinking green power light and a solid orange internet light. I cannot connect my computer using an ethernet cord from one of the lan ports or login to the router.
Message 1 of 6
Highlighted
Apprentice
Re: power light blinking; no internet
According to the User Manual, if the Power LED (not Button) is blinking green the firmware is corrupt. In that case you could try:
- to repair the firmware using the CD that came with the router
- to re-flash the same firmware
- TFTP as a last resort.
Refer to the User Manual to ensure you follow correct procedures.
Message 2 of 6
Highlighted
Virtuoso
Tftp is usually the last thing you want
Jtag is options but also require parts to so it
Myopenrouter.com will have information
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 6
Highlighted
Luminary
Wouldn't that make the Jtag the last thing you want?
Smiley Happy
_____
WNDR3700v1 (v1.0.7.98NA) - Router uptime (d:h:m:s): 1155:02:31:46 - How To Check and Change Your Router's Firmware: http://forum1.netgear.com/showthread.php?t=63234
Message 4 of 6
Highlighted
Luminary
The firmware should not become corrupt every couple of months, unless it is a sign of the router dying.
Is it possible that you are experiencing power issues?
If so, you should consider getting a UPS for your router.
_____
Message 5 of 6
Highlighted
Virtuoso
Yeah... Jtag is last thing you can do...
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6389 views
  • 0 kudos
  • 4 in conversation
Announcements
