- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
reset to factory defaults, then restore configuration file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Quick question: I have read many times that it is a good idea to reset a wifi router to factory defaults before, then again after, flashing a new firmware. What I'm wondering is, do I still get the benefit of resetting if I save the current configuration to a file, then restore the configuration file after flashing and resetting to default? Or is it better to just restore my previous configuration manually?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, you will lose the benefit of resetting if you restore from a configuration file. In spite of this, many people do it and, more often than not, there are no ill effects. But the two latest versions of firmware for the R7000 are a prime example where restoring from an older configuration file only leads to grief.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: reset to factory defaults, then restore configuration file?
OK, thanks. A lot more time consuming, but it's done and everything seems to be working well.
