Reply
router not recognizing new ethernet connection
Rhisson
Follower
I am trying to connect my xbox one directly to my WNDR4300 router via an ethernet cable and I cannot get the router to recognize the new connection.  I have tried updatng the firmware and have the most up to date. I have also tried a reset of my entire system and still no luck.  I have tried a different port and still nothing. Any suggestions would be much appreciated.
Message 1 of 2
Retired_Member
Not applicable
Re: router not recognizing new ethernet connection
check the cable and ports   connect a cable to any two ports to verify ports and cable(s) are working, If they light up then you may have a bad box  If they don't replace cable still don't light up replace router
Message 2 of 2
Discussion stats
  • 1 reply
  • 2234 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
