Reply
two wndr3700v2's
950ash
two wndr3700v2's
My switch died so I decided to but another router use it as a switch and try the repeating funtion for the wireless. Seems there are alot of wierd cant use this cant use that like no encryption, can only do one bandwidth but these are dual band routers.
My question is has anyone done this? if so how if not should i get something else?
Message 1 of 4
jmizoguchi
Virtuoso
Re: two wndr3700v2's
You can only us e WEP Encryption
Look at wn2000rpt extender
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
950ash
In the latest firmware WEP isnt one of the options in the wireless options.
Doesnt look like any of the extenders do 5GHz. I thought the 3700 would do both.
Message 3 of 4
jmizoguchi
Virtuoso
only in N mode. you have to use repeat with 54Mbps settings in the router and it will have WEP opton
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2846 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
