Discussion stats
  • 3 replies
  • 463 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
unauthorized message trying to retrieve ID and password
I cannot retrieve my id or password.  I go to the site to sign in:   www.routerlogin.com or net and then when the popup comes up, i click cancel and get unauthorized message.
even when i put in the suggested ip 192.168.1.1  or 192.168.1.0  i get an unaothirzed message....
http://www.routerlogin.net/401_access_denied.htm
401 Unauthorized
Access to this resource is denied, your client has not supplied the correct authentication.
  All i want to do is get this router to enable PORT FORWARDING.....I NEED HELP!!!
Model: R6230|AC1200 Smart WiFi Router Dual Band Gigabit
Message 1 of 4
Highlighted
Sensei
Re: unauthorized message trying to retrieve ID and password
   Is that accurate?
> I cannot retrieve my id or password. [...]
   "cannot" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] I go to the site to sign in: www.routerlogin.com or net and
> then when the popup comes up, [...]
   Which "the popup" is that?
> [...] i click cancel and get unauthorized message.
   What are you canceling?  Is it asking for a user name and password?
And do you "click cancel" instead of providing them?  Or what?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read. Look for "Types of
Logins" and/or "Reset".  Further reading might be helpful, too.
Message 2 of 4
Highlighted
Here is a short video on the instructioins to press cancel and it taking me to unathorized page:
http://somup.com/cq6VDsedxr
How can i get my router password?  I can't even log into this site
Message 3 of 4
Highlighted
Sensei
> [...] the instructioins to press cancel [...]
   [...] using the password recovery feature [...]
   Apparently, your router/firmware does not have "the password recovery
feature", or else you haven't failed enough to trigger it.
> [...] And do you "click cancel" instead of providing them?  Or what?
   Perhaps you should try putting in the appropriate user name and
password.  As instructed in the User Manual cited above.
> [...] How can i get my router password? [...]
   RTFM?
> [...] I can't even log into this site
   Which "this site"?  "routerlogin.net" (and its friends) should point
to your own router's management web site, not some external web site.
Message 4 of 4
