Reply
wgr614v10 VERY SLOW - out of ideas...
Ben_da_destroye
I just upgraded my speed to 200+ mbps. My ISP helped me make sure my modem is functional. When I connect the PC to the modem directly, I get the desired speed. When I connect through the router (wired and wireless) I max out around 40 mbps. My old speed was 70 ish so I know it can handle more. I tried reseting the router to default. I tried many things. PLEASE HELP!
Thank you.
Model: WGR614v10|54Mbps 802.11g Wireless Router
Message 1 of 4
antinode
Guru
Re: wgr614v10 VERY SLOW - out of ideas...
> I just upgraded my speed to 200+ mbps. [...]
   Note: "m" = "milli" = 1/1000.  "M" = "mega" = 1000000.
   If I were paying for 200Mb/s service, then I'd probably be looking to
replace my antique router with a router having Ethernet ports faster
than 10/100MHz.  (And better wireless capability, too.)
> [...] My old speed was 70 ish so I know it can handle more. [...]
   Then you know more than I do.  I, for example, don't know how you got
these speed numbers, or if you did it the same way before and after the
service upgrade.  I would not expect a "Wireless g" (54Mb/s) router to
do 70Mb/s over a wireless connection.
> [...] I tried many things. [...]
   I'd expect that trying a newer/faster router would do better than any
of those (unspecified) "many things".
Message 2 of 4
Ben_da_destroye
Thanks for the reply.
The router has 4 lan ports. The 70 ish that I recall was using a wired ethernet connection. I came to the same conclusion after some research. I am now on the market for a new router in the $100 area. Do you have any suggestions or search parameters?
Thanks again.
Message 3 of 4
antinode
Guru
> [...] I am now on the market for a new router in the $100 area. Do you
   For a start, I'd look for gigabit Ethernet ports (your Windows system
looks ready for that), and "ac" wireless network capability.  (That
would be two steps up from "g".  (b -> g -> n -> ac.)
   With a limited budget, I'd look for a used unit on Ebay.  I'd also
look beyond Netgear.  A couple of years ago, I might have recommended an
R7000, but reports here of problems with recent firmware releases would
prevent that now.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 600 views
  • 0 kudos
  • 2 in conversation
Announcements
