Reply
what is the terminology for....
SpadeNewsom
What is the terminology for using a modem router as an ethernet router.
In other words I want to plug the ethernet cable from a modem (well an ethernet cable in a motel room actually) into one of the ports of my wireless modem router and get internet from that rather than from the phone line directly into the modem router. I will then attach a printer by wire and two x laptops wirelessly.
This must be called something??
Message 1 of 9
jmizoguchi
Virtuoso
Re: what is the terminology for....
there is specific WAN ports aside from LAN ports on this model
hook it up and should able to your motel network as longs they network don't mind different IP then behind the netgear router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 9
Joe_
Apprentice
"Access Point?" What model are you referring to BTW?
Message 3 of 9
jmizoguchi
Virtuoso
DGND3700 has DSL and WAN ports both
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 9
Joe_
Apprentice
Oh. I beg your pardon. I didn't realize that you had posted to the DGND3700 forum. It's the way Netgear has "organized" these forums - a bit confusing, especially for the uninitiated.
Message 5 of 9
jmizoguchi
Virtuoso
With there no other model has dsl modem built-in and WAN ports.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 9
SpadeNewsom
I have a NB6Plus4W. Which is an old NetComm - I thought it was Netgear as everything else I have is Netgear. Stupid me, I will go to NetComm site to see if their product can do what I am looking for. I pensioned it off a few months ago cause it is only wireless G and have just got it back out of the cupboard..
Message 7 of 9
Joe_
Apprentice
SpadeNewsom wrote:
I have a NB6Plus4W. Which is an old NetComm...
...it is only wireless G and have just got it back out of the cupboard..
See if this will help:
http://media.netcomm.com.au/public/assets/pdf_file/0015/52323/NB6Plus4W-UG.pdf
I think you will need to use "Bridging" mode, and just set DHCP and DNS to auto. Wireless G should be OK. Good luck.
Message 8 of 9
jmizoguchi
Virtuoso
2 cents, in existing free internet from the MOTEL has it's own system , adding to existing your own devices will causes issues ....
bridge mode will work on ethernet output at room for existing network using AP to existing ethernet / network may work but that all depends on how motel are setup
some uses guest network system which requires to signup so using AP can causes issues or using own LAN subnet different from Motel network will /may results of failure to work properly.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2087 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
