Discussion stats
  • 6 replies
  • 2291 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
wi-fi
Hi how do I make the user name and password for the 5ghz default instead of the 2.4?
Message 1 of 7
Highlighted
Master
Re: wi-fi
Which router do you have?
You set the ssid and passphrease in the control panel of the router but need the model number of the to help.
Message 2 of 7
Highlighted
Re: wi-fi
model number is R6400
Message 3 of 7
Highlighted
Re: wi-fi
Model no $6400
Message 4 of 7
Highlighted
Re: wi-fi
oops i meant r6400
Message 5 of 7
Highlighted
Master
Re: wi-fi
Yes on the wifi setup page you can set the ssid and passphrease for the 2.4 ghz and 5ghz to different settings .
here is the link if you need to the users manual http://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_07Aug2015.pdf
Page 117 will show a guide on how to set the ssid's and passphrease's.
Message 6 of 7
Highlighted
Re: wi-fi
thank you I'm going to log off and log on to see if it helped
Message 7 of 7
