× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
wireless access point not working after gateway change
Lewist57
WAC104 not working (no wifi) after changing ATT fiber gateway.  The gateway wifi broadcaster is working, as well as other devices directly plugged into the new gateway.
The power, wireless and internet lights are on. Power cycling the unit, and turning the wifi on and off have no effect. Using the Netgear android app on my phone says the device is not there.
What do I need to check/change to get it working again?
Model: WAC104|Dual Band 802.11ac
Message 1 of 2
Guru
Re: wireless access point not working after gateway change
have you tried simply factory resetting and reinstalling it?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 574 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
