Reply
wirelss router
Ahuevini
Follower
wirelss router
I am trying to connect a 4G Cellspot to my Netgear router, and my internet provider said that I need to contact Netgear technical support so that you can process port forwarding  to unblock Port 123 and Port 500 so that I can connect my Cellspot to your router.
Model: JWNR2000Tv3|N300 Wireless Router
Message 1 of 2
Re: wirelss router
And that 4G Cellspot  is?
@Ahuevini wrote:
...my internet provider said that I need to contact Netgear technical support so that you can process port forwarding  to unblock Port 123 and Port 500 so that I can connect my Cellspot to your router.
Netgear can't do anything to your router. What it can do is to tell you how to set up your router to handle whatever port forwarding you need to set up.
That is down to your ISP and the 4G Cellspot.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
You can find the model number on the label on the device.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 277 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
