Reply
wndr4300 and chromecast
gmmataxi
I have a wndr4300 router running version 1.0.2.80 and an receiving a message when trying to connect chromecast.  A screen comes up ad says something went wrong and to check 3 items:  1.  make sure I am not connected to a VPN.  2.  make sure the router is no in AP isolation mode.  3.  check for MAC whitelisting.  I have been into my router settings and cannot find where any of these are.  Any suggestions or help much appreciated as I would love to use the chromecast.
Message 1 of 4
Babylon5
NETGEAR Employee Retired
Re: wndr4300 and chromecast
  1. You would not unknowingly be using VPN, so that does not apply,
  2. Go to the Wireless Settings page and check the ‘Enable Wireless Isolation’ option, the default is ‘disabled’
  3. Go to the Advanced Wireless Settings page and click Setup Access List. This is disabled by default, but may be worth checking.
When you set up the Chromecast do you have to scan for wireless networks and provide the encryption key? If so have you got past that point?
____________________________
Working on behalf of Netgear
My name is Andy
Message 2 of 4
gmmataxi
Thanks for information but come to find out it was the computer also causing it.  Went to another computer in the house and it worked find
Message 3 of 4
ElaineM
Does this mean that the router is working correctly as it should?
ElaineM
NETGEAR Community Team
Message 4 of 4
Discussion stats
  • 3 replies
  • 2487 views
  • 0 kudos
  • 3 in conversation
Announcements
