Reply
wndr4500 or wndr3800
clvk07
Tutor
HI
Which router would reccomend? for best performance and range. I saw some threads about the 4500 that drops connections, any issues I should be aware from these routers? thanks
Message 1 of 2
Alnico
Re: wndr4500 or wndr3800
I have a wndr4500 and it mine is solid. I highly recommend this product to all my friends and family. My only complaints are:
1. MAC filtering - seem to be unable to find a way to apply MAC filtering to only some SSIDs.
2. Only one schedule can be applied to the access filters.
3. No IP/MAC address bypass for Parental Controls. There is a great little bypass utility but it supports only MAC PC devices and Windows PC devices. I would like to be able to exclude other clients - and those - by IP or MAC address instead.
4. No DD-WRT build supports this router yet. I would use this to address the limitations above if it did.
All in all this is one the best routers I have used, and I am a IT Pro...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2413 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
