× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
xbox one connection problems
MageHw
I Cant connect to xbox live with the router
with older routers i used like n300 i had to change something in the firewall settings or lower the firewall setting but on this router im not sure what to do
What is the best configuration for N750 to communicate with xbox one for online purposes
Router is not list the Router is N750 WNDR4300V2
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 12
Accepted Solutions
MageHw
Re: xbox one connection problems
Well for one I had the router setup correctly. I simply for got that I had my Xbox one console set to a static Ip for a different router I was using, before getting my n750 dual gigabyte router. So once I changed my setting on my Xbox to auto configure ip and auto configure DNs, the Xbox one was able to communicate with the router and connect online.
The ip was set to a range that wasn't in range with the new router.
Message 7 of 12
All Replies
Connect by wifi? Wired? (LAN)
Message 2 of 12
Guru
What ISP service do you hav?
What ISP modem Mfr and Model # do you have?
Message 3 of 12
MageHw
It's wired, I contacted support late last night and chatted with a tech that helped me thanks.
Message 4 of 12
Guru
How was the problem fixed?
Message 5 of 12
Exactly.
Help other victims by explaining what you had to do and you will win fans and eternal gratitude from other users.
Message 6 of 12
MageHw
Message 7 of 12
Guru
Thanks for posting. Glad they helped you figure it out.
Message 8 of 12
MageHw
Me too thanks
Message 9 of 12
Guru
Smiley Wink
xbox consoles only need auto IP configuration and uPnP enabled on routers. You can set a IP address servation for the console as well ON the router. This works for single game consoles. QoS is dependent upon your ISP speed service and weather or not you have others using band width while your gaming.
Message 10 of 12
MageHw
Thanks the tech provided me with that same information
Message 11 of 12
Guru
Enjoy.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 39347 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
