Reply
3400 not connecting to Directv Cineman
I am trying to get my Directv Cinema Connection kit connected to my Directv HD24-100 receiver via wireless. I have a Netgear N600 model 3400 router. For some reason, the Directv cinema will not pick up the wireless signal. Distance is not a problem and the router is working fine for all of my other devices; i.e. ipad, iphone, wireless printer, PC, etc.
The Power and Activity lights are both solid green. The WLAN, Coax network and AP/STA lights are not lit. I believe I need the WLAN light to be solid green, showing a wireless signal is being received from the router.
The Direct TV people have walked me through all of the steps. They say their receiver is fine and it is a network problem. I have done a reset on the connection kit. Nothing changes. Any help would be appreciated.
Thanks
Don
Guide
Re: 3400 not connecting to Directv Cineman
Explain what the Direct TV connection kit is.
Luminary
http://www.directv.com/learn/pdf/WiFi_Deca/Connection_Kit_User_Manual.pdf
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Luminary
I would suggest to try different wireless mode and encryption combination
Technical Information
Wi-Fi Standard: IEEE 802.11n (draft)
Bluetooth Standard: Not Applicable
ISM Band: Yes
UNII Band: Yes
ISM Maximum Frequency: 2.40 GHz
UNII Maximum Frequency: 5 GHz
Wireless Transmission Speed: 54 Mbps
Wireless Security: WPA-Personal WPA2-Personal WPS
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
It is a Directv Cinema box, power supply and ethernet cable.
I don't know how to go about changing to a different mode or encryption combo.
Luminary
called.. LOGIN the router and change wireless setting..
read manual.. all there...Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 6 replies
  • 2864 views
  • 0 kudos
  • 3 in conversation
Top Contributors
