Reply
ADSL light blinking and no connection to Internet
Hi team.
Last night I connected to the internet using the Wizard setup and followed the instructions to update the firm ware. After the firmware was installed I lost connection and no matter what I try I cannot get a solid green light (flashes) on the ADSL connection. I can remove the phone line etc and this doesn't make any difference. Netgear Techs were supposed to send me a file to restore the original firmware but I haven't seen this yet. I have confirmed with TPG that I'm getting comms from them (Using old modem now) so it's not the ISP.
Please help me :confused:
Spec's
ISP: TPG
Model: DGND3700
Luminary
Re: ADSL light blinking and no connection to Internet
HARD RESET the router after flashing the firmware
see router reset on my sig below
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I'm sorry mate, but how do I "FLash the Firmware" :confused::confused::confused:
Luminary
see router reset on my sig below and there router upgrade tab. read it
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Flashing the firmware is another term for upgrading the firmware. What jmizoguchi is suggesting is that after the download you do hard reset. This is done by inserting a paper clip or similar into the red ringed hole for at least 7 seconds on the large flat surface with Netgear labels. This returns unit to factory setup so you will need to then reset to work with your ISP. See page 156 of manual which is downloadable from Netgear DGND3700 support site.
With the flashing your software, there should be an option under maintenance then upgrade. If you have the file which should be *.*.*.17 , it should be able to added by using the browse option and then upload[button] (do note to make sure your on a wired connection while you do this). After a few moment the lights should settle down and then you can do the reset with the paper clip, which just makes sure the setting are where they should be (clean as if .17 was installed when you opened the box).
Just when you've done the reset ,log in and check the settings. Earlier on I know auto setup was not always putting the correct information in for the connection , so if you have a problem after reset make sure your modem settings are proper.
Hopefully your isp tech support should be able to help you fill in the fields if auto setup doesn't.
OK everyone, thanks for your support.
I have now successfully connect to the net and this is the only process that worked.
Download the old firmware version: V1.0.0.12 and I had an immediate hook up to the internet provider. No rebooting required, so I would recommend to all in Australia that needs to connect to TPG to NOT UPDATE YOUR FIRMWARE TO THE LATER VERSION WHEN INSTALLING THE MODEM / ROUTER.
Otherwise all is good and I'll sleep well tonight !! Smiley Very HappySmiley Very HappySmiley Very HappySmiley Very HappySmiley Very HappySmiley Very HappySmiley Very Happy
Can't sleep till you tell an entire continent what was missingSmiley Sad. Was there something specific to your isp that was removed in the last 2 firmware's.
If it was a simple enough fix you should mark down your settings in v12 and see if they are all available in v17 or later than v12. be my luck your one of those "annex" people since I think something like that got removed.
Your going to want to pass that along to the techs if its a new issue for them to work on. Like Scubbie said in another post (She can irk later if I miss quoted) saying "v17 should be more a consistent[connections] and secure firmware" so you should move off it as soon as the problem can be detailed.
Please and thank you
Techman
I have exactly the same problem with my N600. I followed the recommended update to 1.0.0.17NA from .12. When the update completed, the router cycled. When it came back up, the DSL light was flashing rapidly and the internet LED didn't light at all.
I verified that the login and password on the Basic Settings page were correct and even checked with Century Link, my ISP, to make sure they were right. I also checked the phone cable and jack worked with a landline substituted for the 3700.
I spent a good 2 hours on the phone between Century Link and Netgear working on the issue with no success. Century Link verified that there did seem to be a line issue, but that it should only impact performance, not connectivity (appt. to fix scheduled for tomorrow).
Next steps included trying out the router with a new cable and a new jack. No success there, as well, even though a landline tested fine for both incoming and outgoing calls.
Finally, I downloaded a new copy of the .17 file and the .12 file. I reflashed the firmware with .17, disconnected everything for 10 minutes, and retried with no success. I, then re-installed .12. This, at least, got the DSL light to go solid green, but the internet light is now showing red. I re-verified my username and password with Century Link, but still no success.
Any suggestions? I'm about ready to retire the 3700 at this point.
Haven't tried myself to see if it fit but if you have a test plug outside your house and an extension cord, you could plug the modem in there. The bad thing there is if it works , your liable. Age shouldn't be a factor too much if you have a newish box outside with working voice and don't re-screw in house too much but how old the wire inside. Most wire will have labeling like cat3 or greater, that's what was originally run into my home even though I replaced with plenum cat 6 (overkill but I didn't have cat 3 or 5 to run) on a shorter run to box (line was dangling out from the siding).
**Either way** when the tech comes tomorrow they'll have a device to plug in when your modem connects and do their own official tests on the line and do the "you should use our modem" jig if they can't get your dgnd3700 to connect with you.
Virtuoso
When you say CenturyLink are you in the old Qwest territory? If so you should verify your ADSL settings; VPI = 0, VCI = 32, DSL Mode = Auto, Transfer Mode = ATM. Or go to the Setup wizard and have it re-detect your connection type.
DGND3700v1
Virtuoso
One other thing to check (if Qwest). I've seen Qwest tech support tell people to use PPPoA (which is what most of Qwest is), but the connection actually required the PPPoE setting.
DGND3700v1
I bought my DGND3700 today and just installed it and the exact same thing happened to me. It was working and as soon as I upgraded the firmware all I got was a blinking adsl light. I reset to factory setting twice & re-installed the firmware to no change. I knew my line was working as I could connect to the internet with the old modem. Anyway I figured I would load the original firmware back on and it worked straight away. I wonder if Netgear are aware of this issue? Not that it matters but my ISP is iinet. Everything else was good not 1 Disconnect tonight where I had been getting about 6 a day with the Belkin modem and router
HI
I have the same problem with version 17 - Netgear are working on a new version 19 but it is only in beta.
i have reverted back to version 12 and am sticking with that version until version 19 comes out
Don't know if this is the same issue, but hopefully will help you ...
I had issues with my DGND3700 whereby the DSL light would flash and the router would show the modem status as "Connected", but the internet light would be solid red, no IP for the ADSL interface, and connection status would always show as "Off"
Unfortunately Netgear support appeared clueless on this issue, advising not much more than a number of factory resets
Luckily my ISP indicated that the times I was trying to connect were categorised as "password error" issues at their end, and having read in a forum somewhere that the DGND3700 would ignore all characters following an ampersand I tried removing that, but the issue remained
On removing all "special" characters from my ISP password and going with a long alphanumeric I was finally able to connect
Still have a support case open with Netgear support, trying to get them to tell me what characters the field will / will not accept, and whether any other fields within the configuration suffer from the same limitation, but nothing as yet ...
Should've mentioned that I had the same issue whether on 1.0.0.12 or 1.0.0.17
Response from Netgear Support today:
"For password and name you cannot use any special characters."
A little on the ambiguous side I know, and obviously @ is acceptable in the username field or my connection (and presumably many others) would not be working ...
Tutor
If you got the DSL light steady green, that's good. Go back to the GUI of the modem and go to the left-hand side, the first option there is Setup Wizard. Click on that and select Yes and click Next. It will detect the connection type. If it says PPPoE or PPPoA detected, just click Next and type the login and password from Centurylink and click Apply. Check then if the internet light is still red or green.
Tutor
If you have the DSL light on solid green, most probably the line is working fine. If the Internet light is red or off, it is not a Firmware problem, it is more on the settings of that modem. It may have not configured properly. You can try to run the Setup Wizard on the NETGEAR GUI to let the modem detect the type of connection you have from the ISP. For Centurylink, most of them has DHCP. Most of Qwest subscribers has PPPoA connection, although some has PPPoE.
Yep, blinky green light...
Out of the box I was able to get the DGND3700 up and running. Thought to check the firmware and version 1.0.0.17 was available. I D/L the correct version for North America. FLASHED. And DEAD. BLINKING SYNC LIGHT.
Connected my old modem, went to Netgear's site and d/l the old 1.0.0.12 firmware and FLASH. Solid green DSL Light....
I agree with raegten01... The NA 1.0.0.17 firmware version is buggy for me (AT&T DSL in Central Florida (Orlando). DSL will not sync up.
So, can the version 1 - DGND3700 router be identified as not have a trailing version number following the model number?
If so, after reading that there is a problem with V1 then have the retailers PULL THE PRODUCT!
:mad:
Discussion Stats
  • 18 replies
  • 51912 views
  • 1 kudo
  • 11 in conversation
Top Contributors
