Reply
Novice
Can i used a actiontec as a wireless repeater
model GT704-WGB ACTIONTECH
MY DGND 3700 N600 WIRELESS DUAL BAND GIGABIT ADSL2+MODEM ROUTER
is not reaching my xbox 360 so i wanna use my ACTIONTEC as a wireless extender/repeater
Is tha posible ?And how can i configure it?
Luminary
Re: Can i used a actiontec as a wireless repeater
you will decrease the security if you can even repeat with actiontec
54Mbps/WEP will be your setups
I would look extender wn2500rp
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
well my xbox 360 its g54mbps and it supports wpa
How could i set this
Novice
I meant to say the Actiontec supports wpa
but my xbox it 54mbps
Luminary
doesn't matter.
repeat are commonly use WEP/54Mbps settings
if you do not see repeating option in actiontec setting then you must BUY extender such as wn2500rpt
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 4 replies
  • 2740 views
  • 0 kudos
  • 2 in conversation
Top Contributors
