Reply
Follower
Can't connect to Arris TM722 cable modem
I recently upgraded my cable modem (comcast), and needed to upgrade my wireless router. I choose the WNDR3700. I've gone through "E-Z" install a number of times but still can't connect with wireless. However, I can connect through a LAN cable from the router to laptop.
On the cable modem, the "online" indicator light is flashing yellow, but should be solid green (when attached via ethernet cable to the router). When i connect the modem directly to my laptop with a ethernet cable, the modem is working properly (solid green light).
Cable modem: Arris TM722
Router: WNDR3400
Firmwear: V1.0.0.38_16.0.48
Frustration level: medium-high
Any advice would be appreciated.
Jason
Tutor
Re: Can't connect to Arris TM722 cable modem
3400 or 3700 ?
Flashing amber indicates that the connection link is good, but it cant get an IP.
It is likely that you can only get issued one IP via the cable provider, and since your laptop had been connected to the modem then there is a valid IP active.
Two choices (I think)
#1
So connected up as it should be working, go into the router web page.. www.routerlogin.net or the routers IP if that doesnt work (default is 192.168.1.1).
Under "Setup" click "Basic Settings"... It may take 1-2 seconds for the proper page to load. At the bottom of the page that loads it should have a section to put a Router MAC Address.
If your using your Laptop then just click "Use Computer Mac Address" Then click Apply. Rebooting your router should then allow it to get an IP.
#2
Your other choice would be to connect the laptop to the modem.. When the laptop has a valid connection to the internet then log open up a command prompt an issue the following command
"ipconfig /release"
Unplug your ethernet port, and hopefully your modem will now accept a connection from a new device.
Luminary
sounds like if you are online is blinking on arris then this ISP issues.
you likely to have poor signal causing not able negotiate connection with arris modem to the comcast network
I would put trouble ticket and have someone come and check.
also if you have moved your cable modem to different location in the house that also will cause the issues if this was used in different rooms
typical issues if you moved in the house then line you are using are coming fro the first splitter and loosing the signal strength
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Tutor
Fellow Comcast user here.
Are you power-cycling the modem when you change the connection from your laptop to the router? Just for grins, try this:
    This is functionally equivalent to jlewter's suggestion #1, but doesn't require you to change any configuration.
Tutor
I didnt know if the lease would be thrown out when the modem was disconnected...
TBH, I didnt even consider it ;( ...
Luminary
if arris has battery.. that needs to be removed for power cycling the unit on modem
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
June's right - I forgot "TM" stands for "Telephony Modem". Remove the battery and wait a couple of minutes as step 1a.
Tutor
One more quick thought:
I just took a quick look at your modem's instruction manual:
http://www.arrisi.com/support/guides/_docs/TM722_User_Guide_Std2-1.pdf
Instead of removing the battery, you can use the Reset button:
Use the Reset button, on the back of the Telephony Modem, to reset the modem
as if you power cycled the unit. You may need to reset the Telephony Modem if you
are having problems connecting to the Internet.
Luminary
I always use removing battery. reset may work but best to kill all the power ..
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
You may be reading the lights incorrectly. I have a 722 sitting next to me and the lights are confusing. Are Your "online" light is a function of whether the modem can acquire or not and doesn;t change depending on what host is connected to the modem. Now if your "Link" light is what you mean, then an orange/amber light indicates a 100Mb connection while green is gigabit. Regardless your issue with the router connected is most likely ip assignmwnt to your router from comcast. The fix is most likely power cycling your modem first without any host device connected. Since the 722 has battery backup either remove the battery and unplug it or simply push the reset button on the back of the modem then connect your router to it. It should then get an IP from your isp.
Hey guys, serious newbie question here. Do I need to worry about whether my cat 5 cable connecting the Arris modem to my wireless router is a crossover cable or a straight through cable?
Here is a quote from the manual:
Ethernet
Ethernet is a standard method of connecting two or more devices into a Local Area
Network (LAN). Use the Ethernet connection if your computer has built-in Ethernet
hardware, does not use Windows, or you want to share the Telephony Modem connection
with several computers.
Note: To connect two or more computers to the Ethernet port, you will need a
hub or broadband router (available at computer retailers).
The Telephony Modem package comes with a 6-foot (1.9m) Ethernet cable (the
connectors look like wide telephone connectors); you can purchase more cables if
necessary at a computer retailer. If you are connecting the Telephony Modem
directly to a computer, or to an Ethernet hub or broadband router with a cross-over
switch, ask for Category 5 (CAT5) straight-through cable.
Telephony Modem to an Ethernet hub or broadband router without a crossover
switch, ask for a Category 5 crossover cable.
Luminary
straight cable will work just fine
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Apprentice
Most times the cable supplied with the modem (or the router) works. If you don't have any problems then don't worry about it. If you were using the wrong cable then you would be having major problems.
Luminary
Makes no difference. Most unit will auto negotiate so straight or cross will work
It rare to use cross over cables is days
Only time you will use now days for cross is real Cisco router, not cisco/linksys home end router or T-1 connection etc with more in depth setups
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 13 replies
  • 52173 views
  • 0 kudos
  • 7 in conversation
Top Contributors
