Reply
Follower
Cannot connect to router
Hi
I have set up the router (NETGEAR N300 Wireless ADSL2 Router) all ok and can get on the net with wireless on my other laptops.
I have bought a desktop computer (xp pro) which was connected to my mates router. I pluged in the ethernet cable to the desktop then to the router BUT it will not see the router.It keeps saying no connection or low connectivity I look at the ipconfig and it says for the ip 169. But if I use my lap top with Win7 on it and plug in the ethernet it works.
What have I got wrong
THank you
Luminary
Re: Cannot connect to router
possible band network card unless this computer do work with other wired networks
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Apprentice
Firstly, N300 is not the router's model number. Look at the label that is stuck to the router - it should be something like DGxxxx or WNxxxx. From the info provided, I rather suspect you have posted in the wrong forum. (Yes! I know that the way the forums are arranged doesn't make it a "no-brainer" to choose the correct forum).
I have bought a desktop computer (xp pro) which was connected to my mates router...
So let's see if I got this right: You bought this desktop PC (presumably 2nd hand) and it was working on your friend's router. Next, you connect it to a LAN port of your router using the same ethernet cable that was used before, and you cannot establish a connection. Is this correct? What does the that LAN LED show? (e.g. color, steady or blinking).
Check and make sure the ends of the cable are properly inserted in both the PC and the router. Also, try swapping the cable with another one. Try another LAN port.
How far away you're from router? With long cable connection are lost. Make sure Local IP Address it's not already used by another computer.
Luminary
with IP 169.x IP , you will not get this ip because of duplicate IP. It it was, one of the device will get duplicate IP.
usually 169 are sign of not fully communicating at all
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 4 replies
  • 2147 views
  • 0 kudos
  • 4 in conversation
Top Contributors
