Reply
Connecting a Wireless Bridge to my router.
Hi, I recently replaced my wireless router for a WNDR4000 since I heard it has the best signal. So far I'm happy with it but I want to extend the signal by adding a wireless bridge.
My old router is a Linksys WRT54G2 witch I flashed to firmware to dd-WRT for it to be able to support bridging.
My setup:
Modem- WNDR4000- PC,PS3,Printer, Laptop
So my question is how can I set up a wireless bridge so my Linksys router can connect to my Netgear wirelessly and extend the range of my internet?
My netgear router is using SSID name: RoadRunner and the password is a
WPA2-PSK [AES] and channel: Auto
Luminary
Re: Connecting a Wireless Bridge to my router.
you need to use WEP on wireless repeat
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Virtuoso
Also, using WEP in a repeating mode will limit throughput on the link back to the main router to 54Mbps, the repeating will halve that to a maximum of 27Mbps, since you are having to repeat the signal at the repeating device will not be optimum anyway, so your achievable throughput will be very low.
So I set my password to WEP and do I enable wireless repeating on my WNDR4000? Since it's my main router.
Since my devices right now only support 2.4Ghz I turned off the 5Ghz band my 2.4Ghz band is set @300Mbps Do I need to set it to 54Mbps?
I get 27.68Mbps download and 1.83Mbps upload on my laptop. Will it affect my speed's?
Also i'm a noob at this. Do I have to change any other setting's other than setting it to WEP on my main router? WNDR4000
Luminary
sounds like proper speed to me
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
So do I have to enable wireless repeating on my Netgear router?
Okay so this Is what I did, I enabled Wireless repeating function on my Netgear router and set it to Wireless base station and entered my Linksys router's Mac address
So now in the set the Linksys to Repeating and match all of the info of the ssid and password as my main one but can't get it to work. Any ideas?
Luminary
this is how repeat works
http://vpncasestudy.com/download/WDS/WDS_Concept.pdf
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
Broadband internet connection.
- Two wireless routers:
* One connected to your broadband internet connection to serve as the access point.
* One connected to other machine(s) that need to connect to web. This one will need to support DD-WRT.
http://www.makeuseof.com/tag/how-to-turn-an-old-router-into-a-wireless-bridge/
I have a DLink DAP-1522 wireless bridge connected to my Netgear WNDR4000 on the 5ghz band. Using WPA2 security. Works very well.
Discussion Stats
  • 10 replies
  • 7398 views
  • 0 kudos
  • 5 in conversation
Top Contributors
