Reply
Connecting new router to existing network
Hi I have an iMac connected to a DGND3700 modem router.
I have bought a wndr4500 to attach to a sky box for downloading movies wirelessly (on sky+)
I've connected the 4500 to the sky box , switched it on and, whilst it shows its generating a signal on the 2.4 and 5ghz bands, it's not connecting to the internet. I've tried pressing the wps buttons on both modem and new router but there is no connection between the two boxes. Also, I can't get into the configuration page for the new router as I just get redirected to the 3700 page.
I'd be extremely grateful for any ideas.
thanks
rasalom
Luminary
Re: Connecting new router to existing network
if you are using DGN3700 with 4500 then you got wrong device and setup is wrong.
not on clear how it is setup
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
many thanks for the response
Please would you expand on why it's the wrong device. The info from sky indicates that all I needed was a router attached to the sky box. Since I already had a dual band modem/router attached to the computer, I'm confused as to why the WNDR4500 is the wrong device.
Thanks
Rasalom
Luminary
DGND is used with 4500?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Prodigy
As a general rule - ONE network ONE router - if you're going to break this rule, make sure you know what you're doing and why.
You have two routers - a WNDR4500 and DGND3700 - you seem to have connected them in some unknown fashion, as evidenced by the fact that when you try to connect to the 4500 you get the 3700 instead.
If there is no physical connection between the routers, then perhaps you need to explain why you feel you should be able to connect to the 4500 from the iMac which you say is connected to the 3700.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Fordem - thanks for the explanation - being a techno-numpty, I wasn't aware you couldn't connect two routers together. Many thanks Rasalom
Luminary
Rasalom
you can connect two router together only in proper way.
have not exactly see the setups.
explain the goal you are trying to do
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Prodigy
It's not that you can't, but more that you shouldn't - it's an easy way to get yourself into trouble - if you're familiar with routers and know why you're doing it and how it should be done, it can be done.
Discussion Stats
  • 7 replies
  • 3436 views
  • 0 kudos
  • 3 in conversation
Top Contributors
