Reply
DGN1000 - DHCP doesn't work properly
Hi, I've DGN1000 modem/router with fw version V1.1.00.35_ww.
I've a problem. I think DHCP server doesn't work fine. This is my problem:
This is my DHCP configuration:
When I connect the PC with that MAC address, sometimes DHCP server assigns a different IP to my PC:
I think is a firmware problem...This happens also with my laptop and my Xbox 360.
Anyone can help me about this ?
Re: DGN1000 - DHCP doesn't work properly
Im having some strange issues too with the same router. My router seems to assign computers the same IP address?
Any one have any ideas?
Luminary
I would repot the bug to my.netgear.com and open the case
while you do that, use static IP OUSIDE of DHCP on device side
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Ok. Thanks. I'll do that
Hi Guys,
I have a similar or maybe different problem
Well sometimes when I use the Ethernet cable to connect to my DGN1000 , it will assign an IP by DHCP, but I get no internet access however when I switch to wireless it works fine , so I am guessing the DHCP has problems? When I troubleshoot with Windows 7 it won't fix it (or says , Invalid IP Configuration)
Please Help?
Luminary
place google dns on pc side and if you are getting out
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 5 replies
  • 3250 views
  • 0 kudos
  • 4 in conversation
Top Contributors
