Reply
Novice
DGND3300v2 WPS issue
I'm interested to know if disabling the PIN prevents the WPS bruteforce from working on this device.
On my DGND3300v2 - even with the PIN disabled the bruteforce attack is able to exploit the WPS system to return the WPA2 PSK in plaintext in a very short time (less than 3 hours on my router)
Novice
WNDR3300 WPS issue
sabretooth wrote:
By setting the disable WPS pin, the router can not be hacked by what you have been reading.
This is highly inaccurate.
Disabling the PIN prevents a device from connecting using the PIN.
However - the WPS protocol still operates in the background and will continue to respond to the attack.
The exploit not only returns the WPS PIN but also the WPA PSK in plaintext when successful. I was able to break my WPA key in less than 3 hours.
This vunerability is much more severe than people think.
Novice
Re: Firmware Update for WPS Hack
On my DGND3300v2 -even with the WPS PIN disabled the WPS protocol operates in the background and is still vunerable to attack.
The attack will return the PIN and WPA PSK password in plaintext - it took less than 3 hours on my router. This is with the pin disabled and checked to make sure it doesn't accept WPS PIN connections.
Netgear need to release firmwares that switch off the WPS Protocol entirely for these routers to be secure.
Re: Disabling WPS on WNDR3800?
That is interesting. Another poster was successful with the exploit and then disabled the PIN in the firmware (for a 3800 or 4500, don't recall which) and tried the exploit again and was unsuccessful.
This is a WNDR4500 thread. It could be your DGND3300v2 is different than the 4500 (and 3800 where you also posted about this).
As I replied in the WNDR3800 thread to your post, a user with either a 3800 or 4500 disabled the PIN in the firmware and was unable to to successfully exploit the security.
Still, vigilance is critical. No further reports of the 3800 or 4500 being vulnerable to this exploit has been reported on the forum from people who have disabled the PIN. It could be your model that remains vulnerable.
Shiftone:
I just read your post on the 4500 thread. You identified your router as the DGND3300v2. You did not identify your router in this thread so I assumed you were referring to a 3800.
As I posted on the 4500 thread, there have been no further posts to my knowledge of continued vulnerability of either the 3800 or 4500 to the exploit for those who have properly disable the PIN in the firmware of a properly functional router.
However, we all must remain vigilant to problems and security risks.
Novice
thank you for clearing that up.
Novice
Re: Disable WPS - Security Flaw Found
I don't think Netgear plans to release updated firmware, they'd want you to update the hardware Smiley Sad but 3rd party firmware options are available..
Novice
not for the dgnd3300v2 there isn't; or not that I can find. DGTeam seem to have left the scene and the other options don't work for adsl modem routers.
Guide
Re: DGND3300v2 WPS issue
So....
If a person can get a routers WPA-PSK in plain text in 3 hours, isn't that equal to zero security?
I mean
1. Someone can set a 59 digit randomized WPA2 password thinking such a long randomized password is super secure.
2. Someone else sets a WPA2 password called: MyPassword2
If both can be brute force revealed in 3 hours, then the first long password is just as insecure as the silly short second password, right?
If this is true, I'm sorry, but Netgear needs staff working on the fix 24/7 until it is patched for all devices....
Tutor
That's the only resolution to this kind of problem. I heard that in the next WPS standard this issue will be addressed.
Thanks,
Novice
Just a quick report on the new .54 firmware.
Brute forced my wpa key in less than 3 hours again. Netgear have still not fixed this security flaw.
Strange but when I have wps enabled I can crack the wpa in about 5 hours when it is "disabled" I can crack it in about 4 hours. I have done this several times to make sure of the results.
So it would suggest turning of wps makes it easier to hijack the router!!!
As a check to crack the wep took about 6 minutes.
All this was done using a standard Acer laptop running backtract 5R2.
Novice
Anyone with this router needs to report that the WPS vulnerability is still a problem. Netgear need to sort this out as this router is not end of life - therefore they should support us.
There is currently no way to secure the WiFi on this router without using enterprise solutions like Radius servers (not really an option for home users)
This is my recent report to Netgear... I expect they will ignore it. If we all report the issue (including your router serial number) they will have to look at the issue more seriously. I want a secure router.
https://my.netgear.com/myNETGEAR/support.asp
I would like to report the continued security flaw in the WPS system on this router. I have upgraded to the most recent (.54) firmware which enables me to disable the WPS PIN.
HOWEVER, even with the WPS PIN disabled the router is still vulnerable to attack and in my tests will give up the WPA password in plaintext in under 3 hours.
As this router is still supported (not end of life) can you please confirm that you are aware of this continuing issue and can you confirm if you are currently working on a solution?
Kind regards,
David Harley
Discussion Stats
  • 13 replies
  • 3542 views
  • 0 kudos
  • 6 in conversation
Top Contributors
