Reply
Follower
DGND3700v2
Have just purchased this item to replace my DG834PN.
Have managed to connect my laptop, tablet and bluray, but can't connect my desktop.
Have a WPN111 adapter fitted, but it will not connect when using WPA PSK. It connect without security, and it connects to 'old' router without any problems.
Di I need to purchase a different adapter for my desktop, for it to connect to this new router?
Apprentice
Re: DGND3700v2
According to the manual for your WPN111 adapter, it is only capable of using WEP encryption. I would say you need to look for a new adapter that could use WPA2-PSK[AES].
Luminary
Re: DGND3700v2
Adaptger is capable of WPA http://www.downloads.netgear.com/files/GDC/WPN111/WPN111_ds_02Feb05.pdf You probably want to test wireless mode at G only (54Mbps) to use with this adapter.. if that works but no with higher thatn 54Mbps then looking at upated adater will be suitable
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 2 replies
  • 1612 views
  • 0 kudos
  • 3 in conversation
Top Contributors
