Reply
Follower
Disable guest network?
Please help!
N600 Wireless Dual band Gigabit ADSL2+ Miodem Router, DGND3700
My router is broadcasting my secured wireless access point perfectly, called Netgear1.
There is also a unsecured NETGEAR channel that I cannot find to switch off...
I assume it is a guest network - where the hell do I disable this!?
Please help - my neighbours are feasting on my internet access... lol
Apprentice
Re: Disable guest network?
Assuming it's really your router that is broadcasting that unsecured wifi signal...
...and...
assuming it's the DGND3700v1, see page 43 of the user manual.
I have the same problem. Appearing on my available network list is a new one entitled Netgear, which appeared along with my main network at the moment I set up the DGND3700. The options mentioned on p.43, the other networks are not enabled, I thus find no way to turn them off. Any ideas?
Discussion Stats
  • 2 replies
  • 4970 views
  • 0 kudos
  • 3 in conversation
Top Contributors
