Reply
Follower
Does not connect to Windows XP
Im having trouble with connecting to Windows XP (saying router not setup for connection) now it works on my Windows 7 and on another laptop with Windows Vista but not XP...
I have the Ethernet cable Connected from router to laptop.. how can i get it to work on all the windows i have listed
Luminary
Re: Does not connect to Windows XP
getting any IP from the router ?
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Apprentice
As jmizoguchi is suggesting, it sounds like something a little more basic.
I have a couple of XP machines currently connected to mine via Ethernet cable and have no issues.
The first thing I would check is whether the IP address has been manually set for another router and to see if the new router has a different set of figures to be used.
Ideally you should not need to set the IP address on your XP PC as the router will issue one automatically. Check out this page:
http://www.home-network-help.com/set-ip.html
Instead of setting the IP address to specific numbers, choose 'Obtain an IP address automatically' and you may wish to choose 'Obtain DNS server address automatically' or set this to a public DNS server.
Discussion Stats
  • 2 replies
  • 1749 views
  • 0 kudos
  • 3 in conversation
Top Contributors
