Reply
Extend WiFi Coverage (2 WNDR3700)
Hello,
I have at home 2 WNDR3700 Routers, linked Wirelessly each other using 2.4 Ghz and WEP wich gives me 54 mbps link between then (I Guess).To do that, my first WNDR3700 is setup as the main router and the other WNDR3700 is setup as a Repeater.
As the WNDR3700 is Dual Band, I'm using the 5GHz band with WPA2 (both routers). This setup gave me 300 mbps speed between my devices and the routers.
My problem here is that i cannot stream HD Video using my WiFi. The HD video streaming only works when my devices are hooked up with Ethernet.
I guess this issue is due to the fact that WEP only enables 54 Mpbs between the routers and not 300 mbps like WPA2.
So my question is: Whats the best way to setup my 2 WNDR3700 so i can stream HD content? I have 2 Apple TV2 running XBMC on both sides of the network getting content from a NAS, wich is linked with Gigabit on the reapeater router
Or is it better buying a range Extender like WN3000RP or WN2000RPT replacing the WNDR3700 repeater?
Whats the difference between a Repeater and the Range Extender?
Also, i noticed that sometimes the Wireless link dies and the second router gets offline.
Both routers are on the same floor, with a 50 meters distance from each other with some doors and walls (not Drywall) on the way.
Can anyone help me?
NAS 1: ReadyNAS Duo: 1024 MB RAM : 2 x 750 GB Seagate : Raidiator 4.1.6
NAS 2: ReadyNAS NV+ RND-4250 : 1024 MB RAM : 4 x 750 GB Seagate : 4.1.4
Router: Linksys WRT-600N Dual Band Gigabit Wireless a/b/g/n
Retired_Member
Re: Extend WiFi Coverage (2 WNDR3700)
Run cat 5 between the two and then use 2nd as an WIRED AP.
Is there any other way round? Because cant run cables between them.
Luminary
Get extender to keep the performance and encryption to the highest
Or use power line device and make 3700 as an access point
http://kb.netgear.com/app/answers/detail/a_id/965
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Apprentice
Yes!
Perhaps, but may also have range issues judging from what you said.
Repeating can only use WEP (at most) and is consequently limited to a max. link rate of 54Mbps. On the other hand, Extending will support the higher higher modes as well as WPA2.
This could be due to the distance between the two units. (See below).
...with a 50 meters distance from each other with some doors and walls (not Drywall) on the way.
This distance, combined with obstructions, may be a bit much, and could likely be the cause of lost connection between the two units. To test, move the 2nd unit to within, say, 17 meters and check. Increase the distance incrementally and continue checking for lost connection.
If this is the set distance and obstructions you have to deal with, it is very likely that you may encounter loss of connectivity issues even if you were to use a WN2000RPT or WN3000RPT. You may wish to confirm that this is the situation you are faced with. If so, June would be in a much better position to advise you on what to use. (Maybe Engenius products?).
Luminary
From based on OP solution list ,I would not suggest engenius for the purpose yet but willing to sacrifice all the 3700 future, there is other solutions
50 meter is about 160ft , that is quite large distance you are covering.
If wall is not drywall ,what is the construction in details. That is more important to know the obstruction from A to B point
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Joe and June
Thank you very much for your help.
Joe:
1 - Is there any method to build a link between my 2 routers with 300 mbps?
2 - With Range Extender, may I have 300 mbps at the end of my network?
And it will Extend both Bands (2.4 and 5 Ghz)?
And if i change my Repeater for the Range Extender, this Repeater will
not be used anymore, right?
3 - Is it possible to link the 2 routers with some power line device, instead of
running cables through my home? (I have never seen powerline device in
my country). Our Electrical Agency has not approved this tech yet so is
not for sale around here. But if it works (and how fast), i cant buy it from
Amazon.com
Joe and June:
Here in my country (Brazil), walls are usually built with bricks or concrete. Stronger materials then Drywall used in the US. Our walls for sure interfers on Router Signal broadcast. This is the reason I have 2 Routers.
I've been trying to setup a fast wireless network for quite sometime. The netgear routers are my best bet until now. My only issue is with HD movie stream.
Thanks again.
Luminary
If brick is used,I would say using repeating is out of questions.
Power line device the best way to go. Brick and conceret will absorb the signal really bad so you other choice if you can not get power line device then you may need to run CAT5 cable outside wall .
I would suggest to consult some local tech/installer Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
June,
So i cannot link my 2 routers with WPA and get 300 Mpbs?
And even with Range Extender, it wouldnt help?
Luminary
You can not assume works or not
At this point you need to test out yourself with real setup but I can tell you brick ,concrete is bad start
You discuss all day and you will not get any better that you may want to hear. Possible to work but expect lower signal
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Apprentice
Using power line to connect your 2 routers should enable you to use WPA2. However, be aware that you will be limited by whatever speed the power line device you choose is capable of. You need to investigate that as well.
Another matter altogether is the subject of "getting 300Mbps". To find out more on the issues that may be involved, it may be a good thing if you were start by reading the following thread:
http://forum1.netgear.com/showthread.php?t=68658
Again, as June said, it is not possible to say how well this will work without trying it. As I mentioned previously, if you presently have range issues between your 2 routers, it will very likely affect you when trying to use a Range Extender.
Thanks guys...
Im going to try both solutions and pray to one of them work out.
With range extender, my bandwith is going to be halfed too?
Another thing.. Today i tried to link both routers using 5ghz and using 2.4 for the pcs and HTpc. And guess what.. 4 devices running fullhd content without lags... The only issue is still the wifi covarage. Even linked wih 5ghz its still droping. Smiley Sad
Apprentice
Go to the link provided and read up on the WN2000RPT:
http://support.netgear.com/app/answers/detail/a_id/14239
Note: Extender is 2.4 GHz only.
Expected. 5 GHz has less range than 2.4 GHz.
Luminary
seems common result lately seen is if device is connected to extender to ethernet cable have better results over extended SSID you can create to make wifi device to connect extender but seems to have loose the bandwidth
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 13 replies
  • 7639 views
  • 0 kudos
  • 4 in conversation
Top Contributors
