Reply
Genie 2.2.28.24, caused Runtime Error
Hi guys, 1st post on here.
MS XP PRO SP3.
Netgear WNDR4000 (FirmwareV1.0.0.90)
Everything working OK, had Router for about a year.
Yesterday, updated to latest Genie 2.2.28.24. Rebooted network.
This evening, got screen pop up:
visualc++ Runtime error c:\program flies\netgear genie\bin\netgeargenie.exe
Genie icon on Taskbar not there, it had closed shutdown itself
Any suggestions, please?
I did a google search & did not find anything relevant.
Thanks.
frrussre
Re: Genie 2.2.28.24, caused Runtime Error
I'm also experiencing this error since the upgrade. I'm using a Netgear N600 router. This error is generated on both my desktop system (a CyberPower with AM3 motherboard) and my HP laptop (a Pavilion DV7). Both systems run Windows 7 64-bit. I experienced no such problem prior to the latest upgrade of the Genie software.
Rthamper, I did a Windows restore, to before Genie. update. Did not reinistall update. Running on old version, no more errors, pop ups. Frrussre
Retired_Member
Delete it! What is the benefit of using it anyway? I used a 4000 since 2011 until last week and never once loaded genie. Hell netgear at times has enough problems writing firmware.
Discussion Stats
  • 3 replies
  • 3053 views
  • 0 kudos
  • 3 in conversation
Top Contributors
