Reply
Novice
Genie thinks WiFi connection is not enabled
Everything appears to be working fine with my router, except the home page on the Genie software says, under WiFi Connection status: "NOT ENABLED." When I click on that tab, it says, "Can not scan the wireless networks. Make sure your wireless adapter is turned on and is not disabled." When I click on the "Refresh" button on that panel, nothing changes. Is this a problem I need to address? I remember that, when I first installed the router, it said "ENABLED," but after downloading the latest Genie firmware, I started getting the "NOT ENABLED" error message. I'm not sure I know what my wireless adapter is, nor how I would enable it.
Virtuoso
Re: Genie thinks WiFi connection is not enabled
Is the Genie referring to the PCs wireless adaptor rather than the router wireless status, i.e. your PCs wireless adaptor is missing or disabled?
Novice
I suspect Genie refers to the PC wireless interface. My desktop PC does not have wireless, and I see the same error message in Genie.
However, when I log in using the router's web interface, it shows wireless as available. Clicking the icon take me directly to the internal wireless settings page of the router itself, not any external adapter.
Wonder why the Genie software has this inconsistency, or is it intentional?
Discussion Stats
  • 2 replies
  • 9333 views
  • 1 kudo
  • 3 in conversation
Top Contributors
