Reply
Follower
Green Flashing Power Light During Setup
So today I bought a WNDR4500 to replace my old router. I followed the instructions, power off modem, connect router to modem, turn on modem, then turn on the router. Here it says wait for the 2.4GHz LED to light up but the only thing my router does is has the power light flash green. I have reset the router and my modem and still nothing different. I can't even get to www.routerlogin.net or anything with my pc connected to the router. Any help would be awesome, thanks.
Re: Green Flashing Power Light During Setup
try holding in the reset button then plug in the power and keep it pressed for 60 seconds, then unplug, release the reset and power up again.
Have a n900 r4500 and have the same problem. Tried the reset and still same.
Worked with Netgear Tech and told me to return the unit, is defective.
there is a way to get around that blinking light. It's just corrupted firmware. I had the same issue when i bought mine....and I am amazed at how dumb tech support is.
http://kb.netgear.com/app/answers/detail/a_id/18989/kw/wndr4500%20corrupted%20firmware%20recovery%20... this fixed it for me and i didn't have to return it. Especially if you can't even log into your router GUI.
Thanks! you saved me I bought it in the U.S. and am now out of the country.
Returning it would not be easy. followed the instructions and dropped the FW in and it now it works like a charm.
Don't be to hard on tech support. That solution is pretty hardcore. Most people would prefer to return a router...
Nice bit of engineering being able to update the FW even when FW is corrupted...
blacksunshine,
In those instructions I do have ONE DUMB question.........
If using windows XP, it says go to the cmd prompt and use "cd" command to navigate to the folder where your firmware is downloaded............ my question is, how do you navigate to the firmware from the command prompt? It just says use cd command. For someone who is intermediate that instruction doesn't help.
place the file on the c drive then keep doing cd.. (enter key)
cd.. (enter key)
cd.. until the prompt reads
C:\>
then your at the start of the c drive where the file is.
Luminary
place the firmware on the desktop
go to Start >run CMD and hit return
first box pops up will already defaulted to desktop
try dir and hit return
you can find the file you save
easier to save tftp and firmware on desktop and follow rest of the command
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
not on windows 7, it defaults to the users (current account your logged into) folder
Luminary
all you have to do it just simple CD desktops and it will be fixed for win7
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
First, do you know which folder the file is in? Let's assume that it is in C:\My Documents\Downloads for Windows XP. Open the command prompt. You can either start by typing
cd \
to take you to the root directory (sorry, folder, I'm an old DOS man) and then
cd "My Documents"\Downloads
Alternatively, you can just type
cd \"My Documents"\Downloads
from the iniial command line regardless of what folder it's in. When changing folders that have long filenames or multiple word names in XP, you need to enclose them quotation marks IIRC. It doesn't hurt to do it anyway.
when I get to the tftp part, it never completes, just kicks back a time out occurred, connect request failed error.
please advise.
Luminary
Sounds like a brick router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I am trying to update my router on a mac as it has the flashing lights as well. However, I cant seem to get it to work with the help posted here or on netgears support site. I get to the point where I am running the CMND and I am getting an illegal operation message. Can anybody help me with updating this firmware?
Luminary
those are windows base command line so in terminal it will not work
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
I'm trying to run the steps indicated, but I keep getting the following error from cmd:
'tftp' is not recognized as an internal or external command'
Any ideas?
Luminary
http://forum1.netgear.com/showthread.php?t=30453
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Thank you Blacksunshine for posting a link to that knowledge base article.
I accidentally bumped the on/off switch of the power strip into which my router was plugged in. It caused the power strip (and of course the router) to turn off for just a split second - but the router immediately stopped working after that.
It is a N900 (WNDR4500) router. It would try to power up, but the radio lights (2.5GHz/5GHz) would not come on and the power light would blink green slowly.
It was like 11PM and I was exhausted, so I did the laziest thing possible - I googled "N900 not working power light blinking green." which took me to this thread. This is one case where the laziest action ended up being the best, because I followed the instructions verbatim on the knowledge base article that Blacksunshine linked in his post, and the router is now working properly again!
I'm sure if I had called tech support, they would have RMA'ed the unit and I would be without a router for several days. And the N900 aint cheap.
Thanks again for the help Blacksunshine, this Bud's for you.
And as for "therugbyman" having problems with "tftp not recognized as command"...you have to enable TFTP in Windows' "Programs and Features" settings in the control panel (Win 7), otherwise it will not work. This is covered in the knowledge base article.
The green power light is blinking & cannot login.
Do you mean with this instruction we can install firmware without login?
Does it work for MBR1515LVW? If yes, what IP sould I use as :
IP Address, Subnet & Gateway? The router address is 192.168.0.1
Luminary
Try tftp method
If that still fails and unit is still under warranty then contact support at my.netgear.com
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
jmizoguchi wrote:
Try tftp method
MBR1515 is made for Verizon, it was under warranty & Verizon replaced it but firmware is upgraded from V1.2.2.68 to V1.2.2.77 that changed the interface completely.
Verizon has access to update firmware of router remotely it is V3.2.3.55 now.
Is it legal Verizon does such a upgrade without our autorization?
How can we stop it or downgrade the firmware?
Luminary
Most these unit are ISP branded so in this case Verizon has rights to do whatever under their rules and also providing the better service by pushing better service
You need to contact Verizon support to deal with the issues Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 23 replies
  • 42253 views
  • 0 kudos
  • 13 in conversation
Top Contributors
