- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Guest connection to N600 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've had this router for a long time, and never needed to have a guest connect to the Wi-Fi in my house. Now I do, and don't know where to find the guest network access password. I'm sure its in the setup somewhere, but where?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You didn't provide the model number of your router.
Generally, when you log into your router, you should see a Guest Network panel or tab on the home page. Click on it to access the guest network settings. Setup should be self-explanatory. If not, go to http://support.netgear.com, enter your router model and download the user manual.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
