Reply
Follower
Help Please! No WEP on WNDR3400?
Hi all,
I just bought the Dual band N600 WNDR3400v2 based on some great review. However, during the setup, I realized that that router does NOT give me any option to pick the WEP as the security option. While most of my devices can support the newer WPA, I do have some legacy wireless devices that can only work with 40-bit/64-bit/128-bit WEP. Is it true that Netgear remove the WEP support in all new devices? My firmware version is V1.0.0.16.
Thanks!
i-SpY
Luminary
Re: Help Please! No WEP on WNDR3400?
You can use ONLY 54MBps setting in the router for WEP
Means you will NEVER use N speed until you change to WPA or WPA2
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 4897 views
  • 0 kudos
  • 2 in conversation
Top Contributors
