Reply
Novice
How to Turn off MAC Filtering
I have a Netgear WNR2000v2 Router, I have been having problems connecting to the router from my wireless printer. Spoke to HP's Tech Support today and after several checks he needs to Turn Off the MAC Filtering on the Router so that he can do further tests tomorrow morning.
I have the Routers username and password but when I go into the Router management I don't know where to look and what to change.
Can someone help me please
Novice
Re: How to Turn off MAC Filtering
Inside router management, go to wireless settings under advance and click set up access list.
Novice
I have gone to Wireless settings and there is No advanced option there.. this is a copy of what I get on Wireless settings
Wireless Network
Name (SSID):
Region:
Channel:
Mode:
Security Options
None
WEP
WPA-PSK [TKIP]
WPA2-PSK [AES]
WPA-PSK [TKIP] + WPA2-PSK [AES]
Security Options (WPA-PSK)
Passphrase: (8-63 characters or 64 hex digits)
Novice
I have also checked further down the list and found this under Advanced Wireless settings.
but there is not a lot of bits on here
Wireless Card Access List
Turn Access Control On
Device Name MAC Address
Novice
You are refering to the wireless settings under "SETUP". there is another wireless settings option on the menu on the left of the router configuration page under "ADVANCED"
Wireless Network
Name (SSID):
Region:
Channel:
Mode:
Security Options
None
WEP
WPA-PSK [TKIP]
WPA2-PSK [AES]
Novice
Available Wireless Cards
Norma-TOSH
BLACKBERRY-73DD
keefyboy-msi
Wireless Card Entry
Device Name:
MAC Address:
This what I got up when I went into advanced> Wireless settings> Wireless Card Access List>Add
and it shows me the above Wireless Card Access List
Please don't think I am thick, I am not used to playing around with the routers settings....
Luminary
mac filtering is OFF at default so unless you enable it it is NOT using.
under router interface, check ADVANCED >wireless setting for access list (same thing as mac filtering)
you are in the right place... TURN IT OFF
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
Right I understand now, and the box is not checked so it is off then. Many thanks, sorry to seem to be a bit slow on it, but i put it down to my age...Smiley Surprised
But all sorted now, thanks again for your help.
Keith
Discussion Stats
  • 7 replies
  • 27731 views
  • 0 kudos
  • 3 in conversation
Top Contributors
