Reply
How to block or disconnect one wirelessly connected device?
I have the:
Netgear Genie
WNR1000v3 - Firmware Version V1.0.2.60_60.0.86
How to I block one specific wirelessly connected user from my network?
The netgear WNR1000v3 manual online is for version 1 only & looks different than the current 192.168.1.1 login/screens
Re: How to block wireless access - WNR1000v3 - Firmware Version V1.0.2.60_60.0.86
N150 Wireless Router WNR1000v3h2 User Manual Page 36 at: http://www.downloads.netgear.com/files/GDC/WNR1000V3/WNR1000v3h2_UM_21OCT2010.pdf under Restricting Wireless Access by MAC Address, shows screenshots and refers to menus that do not exist in the current Netgear Genie. Smiley Sad
Guide
Are you logged into the router via a browser to make that change?
Yes on Google Chrome via 192.168.1.1
Does anyone have a way for me to block one wirelessly connected user?
I have the:
Netgear Genie
The netgear WNR1000v3 manual online is for version 1 (not V1.0.2.60_60.0.86) and looks different than the current "192.168.1.1" router pages.
See Page 36 at:
http://www.downloads.netgear.com/fil..._21OCT2010.pdf
Under Restricting Wireless Access by MAC Address, it shows screenshots and refers to menus that do not exist in the current Netgear Genie.
I'm wanting to be able to disconnect/block one of my kid's access to the internet until they've completed their chores Smiley Very Happy
Luminary
Re: How to block or disconnect one wirelessly connected device?
You can not disconnect a user on the fly.
either to use ACL and manually add mac address when you want to allow it or use Parental Control if router supports it (netgear.com/lpc)
Off course ACL is half good because if there is surrounding wireless with no security they use that.
http://www.mobicip.com
it is NOT free subscription base and should control better even in the house or outside
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 6 replies
  • 4517 views
  • 0 kudos
  • 3 in conversation
Top Contributors
