Reply
How to enable ping on WAN and where is the firewall?
Hello,
How do i enable the ICMP protocol on WAN side?
I have tried to ping my ip address and on the router log i see ICMP blocked...
Why it is blocked?
second question: Smiley Happy
Where is firewall? How can i set up rules?
Thank you.
Re: How to enable ping on WAN and where is the firewall?
A1) Advanced | WAN Setup | Respond to Ping on Internet Port
A2) The closest opton is probably Advanced | WAN Setup | NAT Filtering -- Open; you are probably looking for more granular control. If you are using NAT, Content Filtering | Port Forwarding/Port Triggering may be whare you want to look.
thank you Dick_W
Discussion Stats
  • 2 replies
  • 17691 views
  • 0 kudos
  • 2 in conversation
Top Contributors
