Reply
Iburst Wireless Modem
I have a problem with my Iburst Wireless Modem, It gives me this error "USB Device Not Support" - On the Router's list, it says is compatible with Iburst..yet is not on the list..
I have done all the firmware updates..its just don't work..should I return the product or anyone to help?
Guide
Re: Iburst Wireless Modem
You need to contact Iburst for support. This is the Netgear forum.
Luminary
if you are referring to 3G Data modem to on MBRxx models and it is on compatible list then call netgear support by calling or use portal at my.netgea.com
forum can not help you on compatibility issues if listed on as compatible.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I have Netgear Router and I wanted to connect it with my iBurst modem...Thanks for nothing
Thanks for decent response..I did contact netgear support and they were very helpful..
Luminary
Glad to assist! Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 4 replies
  • 4004 views
  • 0 kudos
  • 3 in conversation
Top Contributors
