Reply
Novice
Is it possible to connect an older WGR614 wireless router to new WNDR3800 as wireless
Is it possible to connect an older WGR614 wireless router to new WNDR3800 as wireless internet adapter? I don't have a wired ethernet drop in my basement and I want to connect my Denon AVR receiver to my wireless network. Does anyone know if this is possble? I'd prefer not to buy a new Wireless Internet Adapter. Thanks...
Luminary
Re: Is it possible to connect an older WGR614 wireless router to new WNDR3800 as wire
if WGR614 is not V9 or V10 then you can NOT.
you need extender such as wn2000rpt, wn3000rp
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
Thanks Jim. Do you know if the Wireless Internet Adapter WNCE3001 will work just as well as the range extenders (wn2000rpt, wn3000rp)? I want to leverage 5 GHz channel for streaming video and games.
Question about my WGR614v9
Help! I am so new to this forum! I want to start a new discussion, but cannot find out how to even begin, so I am butting in on another discussion (forgive me!). I use my router for a firewall and was wondering why it blocks some of my parish (county, to most of you) library web pages -- I have not listed it on my blocked sites. Is there a way to get around this? Thanks for all help and info you send.
Luminary
NO.. WGR only supports 2.4G only
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Luminary
ops.. sorry... I jus woke from nap so I got brain fart.
any of extender will connect to 3800 Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Hello!
I spent literatly the entire day searching the web and this forum and although it seems to be impossible, I`d like to be certain about it before purchasing a booster.
I moved to a bigger house and had to place my main router in the back where I'm "building up" a small office. The router is actually very good (Linksys WRT160Nv3), the problem is that even with it's good range, I'm not getting a very good signal at the dorms or at the living room.
I have an old NetGear WGR614v10 that's been sitting around and I was wondering if I could use it to "increase the range" of my network without using cables. I was able to configure the WGR614 as a repeater but had to use cables to connect it's LAN port to another LAN port of the Linksys WRT160N(as in this post http://kb.netgear.com/app/answers/detail/a_id/965/~/using-wpn824,-wgr614,-or-wgt624-routers-as-an-ac...).
It did work great (although the network I was getting was a g, not an n). The problem is that in order to use that setup I'd have to place a cable in between the two routers, and unfortunately that's not an option. I tried inserting Linksys' MAC adress into the NetGear one's configs, making sure that the later was a repeater, had a different IP adress (out of the range of the Linksys router) and had the same SSID, then with different SSID's and many other setups.. no success. My question is, is it possible at all?
If so, I`d really appretiate a "step-by-step" guide as my understanding in english is still problematic. I enphasize, however, that I really wanted to be able to keep the Linksys where it is right now (because other computers are being connected to it through cables) while still getting a good signal at the other side of the house, with no cables.
My second option would be purchasing a range extender, such as Linksys RE1000 Wireless-N Range Extender and place it near the bedrooms to improve the signal in that area. Is the RE1000 a good option? Are there better options at more affordable prices? Any other suggestions? Smiley Very Happy
Thanks a lot!
Guide
No you can not connect wirelessly to the Linksys router at all. You must always use a cable. You need an extender.
However, make these changes in the WRT160N. Disable UPnP. Under wireless settings, Beacon Interval 50, RTS and Fragmentation threshold 2304. Set to channel 1,6 or 11. Save settings. Now check your signal.
Luminary
This is most common for using ethernet cables
V10 does support WDS which can setup as repeating (two network devices wirelessly connect). Your linksys also MUST support WDS in order make this work
http://vpncasestudy.com/download/WDS/WDS_Concept.pdf
If linksys do not offers WDS (wireless distraction system ) then you will need to buy extender such as wn25000rpt,wn2000rpt,wn3000rp
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Thanks for the tip! Nonetheles, while it increased a little bit the reception in the dorms, I still don't get full signal in some devices. Thank you anyway!
I'll check the Linksys to see if it supports that feature. But if it doesn't, do these NetGear models work fine with the LinkSys router?
Thank you all!
Luminary
It should work but who knows....
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Great tutorial, thanks a lot! I just couldn`t find at LinkSys' GUI anything regarding bridging, repeating and so on, thereby making it impossible to set it to "repeat" NetGear WGR614 by inserting its MAC adress in it... as suggested in here). I even gave a shot at giving a permission specifically to Netgear router by allowing its MAC address into Linksys filter, unsuccessfully.
I did keep Linksys DHCP enabled and made sure to set that feature out of the other router's ip range. I DID set the netgear device DHCP disabled, with a static IP and set it to repeat Linksys' signal (the master router) as in here
... and I did config the same Channel, SSID, and disabled WEP/WAP/WAP2 etc in both devices... and it didn't work! Smiley Sad
Did I do anything wrong?
I'm out of ideas. Searching online I saw there's this dd-wrt firmware I could upgrade Linksys to (since mine is a version 3, apparently it should be fine), and unleash other features (such as repeating and bridging???). Since Netgear WGR614 already displays that feature, setting both to repeat each other, will/should it work????
Has anybody tried something like that? Is there another way?
Discussion Stats
  • 11 replies
  • 12231 views
  • 0 kudos
  • 5 in conversation
Top Contributors
