- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear C6300 wifi will not enable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear C6300 wifi will not enable
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you set the c6300 up as a router or gateway on page 12 of the users manual if the router question is selected as no the modem is now a gateway from saw in the manual?
Here is the llnk for the manual https://www.netgear.com/support/product/C6300.aspx#docs
- Mark as New
- Bookmark
- Subscribe
- Permalink
The installation guide tells you the order that you need to follow to set up a new device:
>>>> C6300 | Product | Support | NETGEAR <<<<
Can you connect to the device as it shows in step 4 of that guide?
Can you connect to http://routerlogin.net or http://192.168.0.1?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mozes911 wrote:
...the internet page said to call twc (internet company) to switch my MAC address so they could authorize it.
Did you do that?
Page 14 of the manual explains this. It also has this link:
https://elb02.activatemymodem.com/authentication
and a phone number: 1-800-892-2253
You need to sort out two things, first the Internet connection and then the wifi.
Once you have got an Internet connection you can start worrying about the wifi.
