Reply
Follower
Netgear DG834GB v2 with Frontier DSL
I have read online that it is possible to use a Netgear DG834GB v2 with Frontier DSL, but I have yet to figure out the correct settings. Frontier is no help, nor is Netgear. I can see from the the Router Status page of the configuration utility that I have a DownStream Connection Speed of 7638 kbps, but I cannot seem to get the settings right to get an IP and connect to the internet. I have read the TIPS100.pdf file on this forum, but the 'modem' only setting did not seem to work for me. Please help - near wits end!
Thanks!
Luminary
Re: Netgear DG834GB v2 with Frontier DSL
modem mode pdf is to bypass router function to use with other router behind the DG.
you need to get VCI/VPI value from the ISP and need to use that on DG setting to work correctly
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 2494 views
  • 0 kudos
  • 2 in conversation
Top Contributors
