Reply
Netgear N600 Dual Band WNDR3400
I don't have much knowledge about wireless networks so I need to bounce a couple questions off of you guys. I just purchased this router for my home where we're having satellite internet installed next week. My question is, does the installation disc that comes with the router install properly for a satellite based ISP provider? Or do I need to ditch the disc and set it up manually? Like I said, very new to this and any advice is welcome.
Luminary
Re: Netgear N600 Dual Band WNDR3400
satellite modem are usually offer "router function" therefore most that I seen it have to setup as access point with the router
http://kb.netgear.com/app/answers/detail/a_id/965
consult ISP or model of the device. if does router function then above must be done. that also require little more skill than using CD.. this setup will NOT use CD at all
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Thanks for your help. I'll give it a shot and let you know.
Novice
Netgear n600 WNDR3700 access point (AP) setup instructions.
These are my instructions when you have two Netgear n600 WNDR3700. This is for the situation when one is your primary router and you want to set the second as an access point (AP).
1. Log into main router and find out IP subnet and subnet mask and then log off. Default IP address is 192.168.1.1.
2. Log into secondary router that is going to be the access point. I will refer to it as AP1.
To log on... plug an ethernet cable into your computer and plug the other end into any of the four ethernet ports on AP1. These are color coded orange when looking at the bottom of AP1.
Do NOT have any other ethernet cables plugged into AP1 right now.
3. Open a browser and go to either http://www.routerlogin.com or 192.168.1.1
4. The default username and password are
user
password
5. Navigate to Setup->Basic Settings
In Internet IP Address sect select Get Dynamically from ISP.
In Domain Name Server (DNS) Address select Use These DNS Server.
Primary DNS: 8.8.8.8
Secondary DNS: 8.8.4.4
Click Apply.
6. Navigate to Advanced->LAN Setup.
7. In LAN TCP/IP setup enter the IP address that you want AP1 to have.
Example: IP Address 192.168.1.12
Subnet Address 255.255.255.0
8. Uncheck Use Router as DHCP Server.
9. Click Apply
10. Plug ethernet cable from main router to any of the three remaining four ethernet ports on AP1.
NOTE: do NOT plug cable into AP1 Internet port which is color coded yellow. It will never be used will as an AP.
11. Power cycle AP1 by either pushing the power button off/on or unplugging/plug in the power supply.
12. In a browser go to IP address you assigned AP1. In my example go to 192.168.1.12.
13. Navigate to Setup->Wireless Settings. Make any preferred changes.
I want to broadcast both G and N both using WPA2-PSK [AES] security and provide passphrase.
For each check Enable SSID Broadcast
For each uncheck Enable Wireless Isolation
Change the name of the SSID to something other than the default.
Click Apply
14. Navigate to Setup->Guest Network b/g/n and make preferred changes.
I want to broadcast a guest b/g/n. Below is what I change.
Check Enable Guest Network.
Check Enable SSID Broadcast.
Check Allow guest to access My Local Network.
Change the Guest Wireless Network Name (SSID) to something else.
Change the security to WPA2-PSK [AES] and type in a passphrase.
Click Apply.
15. Navigate to Setup->Guest Network a/n and make preferred changes.
Final notes:
Two settings that drove me batty and prevented the AP1 from working all the way through:
1. Uncheck Enable Wireless Isolation in Wireless Settings or your wireless AP won't be able to access the internet. Your wired AP will work but wireless won't.
2. Check Allow guest to access My Local Network in Guest Network Settings or the guest computer won't be able to access the internet.
Make sure to change the default password to access AP1.
Maintenance->Set Password
Take backup of AP1 settings
Maintenance->Backup Settings
Hello,
Nice post...
But if in want to use AP1 as wired and wireless acess point, i have to hook up a cable between my 2 routers and set the same SSID or the SSID must be different from each other?
Because this router can be set as wireless repeater, but in my experience the wireless link is not reliable. So i want to run cables between them.
Thanks
Japex
Virtuoso
It is normal to use the same SSID, same encryption, but different non-overlapping 2.4GHz channels any two from 1, 6, or 11 (or different 5GHz channels). Depending on the number of wireless devices you typically have connected, and their locations, and the channels used by neighbouring networks, it can sometimes be better to use the same channel for both.
Luminary
if you are planning to roaming around then use same SSID but if you are going to use separately for wifi devices on remote are then you can use different.
it will be more preferences that you want other than MarsMug's explanation of channel choices
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
All I know now is, after wasting 5 hours trying to get on line with my computer in the garage, all I needed was a new Netgear n300 usb adapter to go with my new router.
Discussion Stats
  • 7 replies
  • 67798 views
  • 0 kudos
  • 6 in conversation
Top Contributors
