Reply
Netgear WGR614v9 Wireless Router Not Broadcasting Wireless Signal (SSID)
Hello. I'm currently experiencing problems with my NETGEAR WGR614v9 Wireless Router, which is plugged into my Motorola SVV5222 SURFboard Digital Voice Modem provided by our ISP, Optimum Online. For some reason, it's not broadcasting the wireless signal to connect to the internet like it usually does. My Nintendo Wii nor my Nintendo 3DS doesn't seem to be able to detect the SSID, or wireless signal. Been trying to unplug it and replug it back in, resetting the different power sources, and even trying to play around with the wireless settings via routerlogin.net. Still, to no avail. This has happened a few times before too, where the wireless signal will just get dropped and unable to be detected. Sometimes we'd have to wait a few hours before it would come back. However, it's been awhile and it still isn't coming back yet. There's no interference because the environment in which the router is in hasn't been altered in any way. I've included a self-made diagram of what our modem/router setup looks like as of right now, with which lights glow and what color they glow: http://i39.tinypic.com/2z83ozk.png
So yeah, I'm not entirely sure what's going on...and I'm not exactly the most tech-savvy person in the world and haven't been able to find a solution online. This is really frustrating and I depend a lot on this router. Can anyone please help?
Luminary
Re: Netgear WGR614v9 Wireless Router Not Broadcasting Wireless Signal (SSID)
http://www.metageek.net/get_inssider_today/
possible channel inferences
use the tool and check if live in saturated area or not since you said will come back in some duration
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Apprentice
How do you know that it's not broadcasting a wireless signal? You only mention "Nintendo Wii nor my Nintendo 3DS". Do you mean that you don't have any computers in your household that uses the same wireless connection? Have you tried with a computer to see if the wireless broadcast of the network is indeed not working? Of course that doesn't mean to say that the wireless radio in the router hasn't failed, but it's a way of diagnosing it.
Thanks. I downloaded it, but it's not really starting up. It's giving me this error message: ""inSSIDer requires the WLAN AutoConfig service, which appears to be stopped. Please start WLAN AutoConfig and then run inSSIDer." Mine appears to be working just fine I think, so I'm gonna have to uninstall this because it's not really working for me.
Because it was not displaying the SSID, when I went to try and find an access point to connect to. Although yesterday I was able to get it back, but then the connection on my Wii was slow and sluggish, and rather unresponsive. It's protected via WEP, and displayed a lock icon when showing up next to my SSID and was in the three bar "strong" green section. I went on my computer to try the internet on there and it too was acting sluggish and slow and unresponsive. My cable modem has also been acting funky lately, as I've stated before. It's been dropping our connection a few times; even today it did again and has been affecting internet performance on my PC. That's how I can tell.
Luminary
try netstumbler if you are using XP
http://www.netstumbler.com/
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Luminary
WEP is not protection anymore.. it is hackable so I would suggest to go WPA2. Wii can handle WPA2 unless other computer's can not
if you see the issue with PC directly connected to the modem then I would consult the ISP
also make sure to check router with PC wired to the LAN ports not wireless to eliminate the issue with wireless.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
If I download this, how will I be able to use it to detect if there is a problem?
I'm technologically inept, as you can see...so I was just wondering what indicator I should look out for if this program picks up anything, like what it would find and such.
I'll look into the WEP thing, for sure.
Yeah, I was thinking of contacting Cablevision to see if they'd give us a replacement modem since this one seems like it's been giving us trouble a lot more these days. Also, I'm kind of confused about that last part. ^^;
Luminary
You can see the surrounding network with application
If your SSID name has channel that interfere with other SSID is equally strong , it can cause the issues.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Apprentice
Where? I don't see it.
As per said, you should sort out ISP issues first.
I don't think Nintendo can do more than WEP.
Luminary
Sorta wrong to say
Nintendo Wii support WPA2
Nintendo DS lite (original) WEP
Nintendo DSi (2nd gen) WPA
DS family chart
Nintendo 3DS WPA/WPA2
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 11 replies
  • 14712 views
  • 0 kudos
  • 3 in conversation
Top Contributors
