Reply
Follower
Netgear Wireless Gateway 7550
First, I hope this is the correct spot to place this question.
I have an AT&T provided wireless gateway that is listed as a model 7550. The wireless signal is not strong enough to cover my entire home; previously I was using a Linksys WRT54G Router with the updated firmware that allows you to control the amount of signal you are sending out.
What do I need to do to setup the Netgear gateway as a bridge to the router? I disabled the wireless already on the gateway, but I'm not sure what else I'm missing.
Luminary
Re: Netgear Wireless Gateway 7550
http://kb.netgear.com/app/answers/detail/a_id/965
make linksys as AP
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Discussion Stats
  • 1 reply
  • 5918 views
  • 0 kudos
  • 2 in conversation
Top Contributors
