Reply
Follower
Nook Connection Issues
Hello Everyone,
I finally broke down and purchased a B&N Nook reader (Simple Nook) and I brought it home only to find that my Netgear wndr3700 will not allow it to connect. I am not the best at Router configuration so I am not seeing what is missing. Currently I have both 2.4GHz and 5GHz networks enabled with SSID. I am running a MAC Access List, but i disabled it in attempts to get the Nook to connect. I currently have a lot of other electronics (laptop, TV, ipod touch, etc) connecting fine. The Nook can see my SSID broadcast, but when I put in the password, it remains "Disconnected". Can anyone help me with configuring the router so that my Nook can connect?
Thanks in Advance!
Re: Nook Connection Issues
Try setting the router to 54. I didn't have to change anything else, but I don't know if it adversely affects router performance.
Tutor
are you using WPA2+AES for security options?
Apprentice
Yes. If you are lowering from a higher mode to 54Mbps, then performance will be affected. This may not be obvious unless you are doing something like tranferring large files. You may be unlikely to see any performance drop if you are only, say, using email of just surfing.
Discussion Stats
  • 3 replies
  • 1718 views
  • 0 kudos
  • 4 in conversation
Top Contributors
