Reply
Phone not Connecting?
Recently, we have changed our intertnet providers. Before hand we had AT&T, and when I was connected to wifi via phone it would work perfectly. Now though we have Cox for internet service. My phone is connected to the wifi, but more than half the time does it ever work. In small gaps am I able to connect to the internet with it. Other times it's like I might as well not even be on. Any possible reasons?
The wifi works fine for other devices in the house. Example as in my laptop. It connects just fine and am always able to access the internet.
If my problem is confusing what is happening is that I am connected to the wifi and it shows I am. The wifi status icon is up and shows I have a connection. When I try to access a webpage or app that requires the internet, it will not load at all and sometimes say I do not have any internet access. So while it's "connected" I am unable to access anything and it's as if I'm not even using wifi.
Other details:
We have a Motorola Cable Modem: Model SB6121
A Netgear Dual Broadband Router: Model WNDR3400-100NAS N600
And for an extra secruity setting, we have selected the option not to broadcast the wifi so that the only way to connect to it is to know the SSID and connect manually.
I have tried searching for this problem but haven't found anything at all really and few results. I'm thinking this is a very rare issue.
This is just a copy and paste from the same thread I made in Sony Mobile forums. Sadly no luck. If there is any other information that is needed to be known, please go ahead and ask.
Luminary
Re: Phone not Connecting?
If you have not changed routers when you changes the ISP then sounds like it may related to ISP instead of router. Also you state other wifi devices work as well
phone as to simple wifi phone or smartphone using wifi
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
We did change routers. For AT&T we had a specialized AT&T router. When we switched to Cox, we got this Netgear one.
And it's a smartphone. It's a Sony Ericsson Xperia Play. Carrier is AT&T. Android version 2.3.4.
Luminary
you may need to try different wireless mode and encryption combination
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I may try the different encryption. Right now it should be on WPA2. What do you mean by wireless mode though?
Luminary
300Mbps, 145Mbps. 54Mbps
right above encryption
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
All right, I will try setting to different modes first. Though I have another question.
Right now our encryption type is set to WPA2. If I set it to WPA+WPA2 would that still mean I would have to reconnect any other device back up to the router? As it doesn't broadcast and needs to be set up manually.
Luminary
best is broadcast and keep trying the combination for wifi device to work.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Well I tried it by switching between 54, 145, and 300. And switching from WPA2 to WPA+WPA2. Not much help there. Does the same thing.
I would try WEP and etc. but don't want to have to go a fix all the wifi for other devices too.
I am also not allowed to let it broadcast.
I'm thinking of resting my phone as that could be a possible fix.
Apprentice
Infallible wrote:
...Android version 2.3.4.
Firstly, let me say that I don't have an Android version 2.3.4 device.
However, I just bought an Android tablet that is on 4.03. What I've discovered is you must delete/"forget" the profile you had previously created when you connected by simply scanning and connecting to it.
You must then manually enter a new Wifi network to connect to on your phone while the SSID is hidden. After that it should automatically connect.
Caveat: I have tested this in Android 4.03 and I'm not sure about version 2.3.4
Yes, that is exactly what I have been doing. That is how I have to add it.
Basically, it is connected. It shows it's connected too. It just doesn't DO anything. It's like...I don't know. Maybe guest or school wifi.
Apprentice
I have the WNDR3400 (same as yours I believe) and I'm using an Acer Iconia A100 tablet with Android 4.0.3 (ICS) and don't have any problems connecting and using the internet.
Forgive me if I may seem to be repeating things but I just want to be sure about the facts. So you are saying that:
1. You have deleted all wifi profiles on your phone that you may have created by just scanning and connecting to your network.
2. Next, you used the phone's function to "create a new wifi network profile" to connect to.
Provided you used the same SSID and encryption method that matches the one in the router (e.g. WPA2-AES) then it should work.
BTW, saying something like that doesn't really provide any meaningful information that can help in diagnosing the problem. You need to provide information like answers to the following:
1. Can you open a browser?
2. What happens if you enter a search in the browser.
3. What message(s) do you get.
Etc.
Etc.
Some suggestions on things you can try:
1. Enable broadcasting of the SSID with security/encryption still set in the router. Check to see if your phone connects then.
2. If the phone still doesn't connect, temporarily disable the security/encryption in the router. Check to see if your phone can connect again.
Steps like these can help you to determine if you phone's OS has a problem dealing with SSIDs that are hidden or if it has a problem handling the type of encryption that the router uses or it's an incompatibility issue.
Having said all that, this seems to be a problem with the Android OS on your phone rather than the router. You may find better help for that either on a forum for your phone or one for Android. Here's one such forum for Android:
If you search the internet you can find several more like that.
Discussion Stats
  • 11 replies
  • 2633 views
  • 0 kudos
  • 3 in conversation
Top Contributors
