- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port forward rules limited to 9 ports
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Netgear CG4500BD Modem/Router
I have 13 cams. (just got last 4)
I cant add another port forward rule (limited to 9)
so I cant add additional cams in port forwarding.
I can't make a range like 8110-8114 because it calls
for a ending Ip address ( 192.168.0. xxx ). (* see pic )
Suggestions ????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port forward rules limited to 9 ports
Update :::::::::::::::::::
If I don't need to assign a port forward for each camera.
But what port do I input in camera when it says port ?
In blue iris I took out the port #,
i can see the camera inside and outside network...
but the camera ip in blue iris defaults to port 80 in configuration ?
I set another cam the same way defaulting to port 80, it works also.
So - How many cameras can be on one port number ???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ahhhh Ha...figured it out....don't even need port forward since I have no need to log into each camera from outside my LAN....I can see all cams
outside through Blue Iris web server...
